Ford. Mild hybrid BSG controll.
beggernator
Northamptonshire
Hi.
I recently acquired the Belt Starter Generator off of a 2019 ford puma. I believe it is the same model as used on the newer focus and some select us mild hybrid models.
Ford rate it for 11.5kw and it runs on a 48v lithium pack.
For obvious reasons I believe this would be a good mid drive motor.
They can be had cheaply on eBay and breakers yards.
It has a built in inverter that I presume the is controlled via can.
I am currently looking into the possibility of a brain swap to re use the drive circuitry but if someone has already decided can communications that would deffinately be the easier route.
Thanks.
tom.
