DrkAngel
1 GW
Theory
Heat rises - An open bottom box will retain heat nicely,
Using a rotary dimmer powering multiple light bulbs (4-6? 100w bulbs) should provide precise temperature control
While temperature can be precise, direct observation is recommended
Parts:
Rotary light dimmer
light bulbs
digital meat thermometer
300 ºF safe, open bottom "box" w/glass observation window (Plywood, even cardboard, is fire-safe to ~451 ºF)
( PET (Polyethylene terphthalate) is about 250—260 ºC = 500 ºF is too hot - requires fire safe materials!)
wood paint stirrer sticks, spatula, any smooth or desired shape shaping tools
hairdryer, heat gun ?
hack saw or jig saw w/fine wood or coarse metal blade
Method
Place PVC (or other material) sheet on top of "form" (desired shape item.)
Raise into "oven", or place oven over project.
Adjust heat to proper temperature
Observe temperature rise and watch for indication of PVC wilting-melting
When near optimal temperature, remove from oven and form shape using wooden paint stirrer sticks etc
Use heat gun etc. for additional, or finishing, formability
Tips
Cut corners, but leave material for a fold or overlap - a bulky "apron" at corners is difficult to deal with
Heat gun is excessively hot, overheating PVC will create brittleness, use low setting and keep distance from material. It takes time for heat to saturate material ... have patience! Oven preferred, with heat gun for additional or finish forming
Experiment and practice with scraps
This is as much akin to Art ... as it is to Science!
Applicable to different "plastics", just vary temperature.
Parts:
Rotary light dimmer
light bulbs
Method
Tips
DrkAngel said:Various melting points of different types of plastic:
The melting point of HDPE (High Density Polyethelyne) is about 130 ºC
The melting point of LDPE (Low Density Polyethelyne) is about 110 ºC
The melting point of PET (Polyethylene terphthalate) is about 250—260 ºC - Danger - too hot - 500 ºF
The melting point of PP (Polypropylene) is about 160—170 ºC
The melting point of PS (Polystyrene) is about 70—115 ºC
The melting point of PVC (Polyvinyl Chloride) is about 75—90 ºC
Source:
http://www.goedjn.com/essays/botplas.html
The melting point of PMMA (poly(methyl methacrylate)) - Plexiglas is about 180 ºC 356 °F
ABS (Acrylonitrile butadiene styrene) (chemical formula (C8H8)x· (C4H6)y·(C3H3N)z) is a common thermoplastic. Its glass transition temperature is approximately 105 °C (221 °F).[1] ABS is amorphous and therefore has no true melting point.
POLYCARBONATE (Makrolon®, Lexan®, Zelux®) Melting point : 300 - 310° F (149 - 155° C)
Forming, or shaping temperatures, are several degrees cooler.
