EVnewbie
Hello All,
I have been studiously reading the reports, concepts, dreams, realities and chaos that is on this board and pondered a few things. Although I thought building up my Norco One25 hard tail dirt jumper would be a good idea, the aluminum frame and the shortness of it cause me to pause. I do have a 2005 Giant Stiletto chopper bike laying around and it seems to be the best format for my first ebike build. The steel frame, it's durability, 180mm rear disc brake and length give me room for screw up....errrr, room to put in what I want.
If you wonder what a Giant Stiletto looks like, here is the link: http://www.bikecyclingreviews.com/Giant_Stiletto_Its_Sharp.html
My first concern with the Giant is front disc brakes and I can have those with the Schwinn OCC chopper suspension forks for $300. They have the 1" steering head I need and will make it look more like a chopper so no harm done. It requires a 24" front disc wheel which I do have, it is a SAS Combat double wall 32mm wide rim with disc and 3" wide tire so that is complete. Have to get the fork before anything else and it is $300 so... hmmmmm.
I have a powerpack BMC motor with 35 amp controller. It was the hotrodded scooter that lived in 2005-2006 until balancing issues with the SVR AGM batteries destroyed the pack. The 36V 35 amp motor screamed and that little scooter would cruise at 23 MPH all day, take the steepest hills without issue and never overheated. I plan on using that for the Giant Stiletto but use a Cycle Analyst to limit the amps to 25 or so at 48 volts.
Gearing, this is the problem. The motor will spin at 3,775 RPM at 48 volts so I need to gear it down so it will be usable. My plan is a Stanton 5:1 gear reduction that uses 1/2 inch thick (13mm) gears riding in a 3 cc gear oil bath for lube and to keep it quiet. Stanton offers a freewheel adapter that fits on the output shaft and I'll run the standard BMX 16T (or smaller if I can get away with it) freewheel.
Since the drive gear is 16T and will spin at 700 RPM max, it makes it critical to step it down yet again. The NuVinci hub has a dual gear setup, one for pedaling (16 to 22T) and the other for a motor at 44T. This will get it close but I wonder if I can change the motor gear for something larger. Maybe I can go with a 60T crank gear and attach it to the 44T? This would bring the max speed of the rear input down to 187 RPM, I can't pedal that fast but the peak efficiency of the motor is at 60% speed so I can pedal that fast. When the motor is at it's peak of efficiency, it calculates out to 27 MPH which is good enough for me. I pedal at 100 RPM which would put the speed at the motors peak at 27 to 30 MPH.
Since it is my first ebike build, but not my first "e build" (the scooter was that) I find the Giant Stiletto to be good for the steel frame and when the chopper fork is added, the thing will be over 6 feet long. Very hard to fly over the bars with a beast like that! My son does not want to give up his Norco One25 and I prefer my Iron Horse freeride bike to remain powerless.
The costs for the build are stacking up along the lines of this:
Schwinn OCC disc brake compatible chopper suspension fork $300
NuVinci 24" wheel with dual 44/16T sprockets $430
Headway 51.4V 15Ah LiFePO4 battery pack (when available) $600
Stanton 5:1 gear box $170
Cycle Analyst with 25 amp external shunt $150
______________________________________________
$1,650
This thing won't be cheap! Luckily I have the bike, the motor, controller, throttle, brakes, tires and everything else I need. Is this a good design? The final rig will run 24x3.00 tires, front suspension and disc brakes all around. The only part that makes it a time constraint is the Schwinn OCC suspension fork, I can get them for $300 now on ebay...but maybe not next week. If I buy the fork, I am committed to the build since my wife would kick my arse for dumping money into something I wont ride.
Am I on the right path, the wrong road, stoned, stupid or should I stay on the porch? I have noted that there is no buzz about the Stanton 5:1 and 18.75:1 gear reduction boxes that they make for 32 to 49cc engines. Wonder why but it is either hub motors or RC motors around here so the Stanton boxes don't fit into the equation. Just wondering...
If it is a bad idea, please let me know...don't want to start buying a $300 fork that I can't use for anything else.
$1,650
