Wishes
ebike11 said:Wishes said:ebike11 said:thx Wishes!
How high of a driver sprocket would be too high when trying to increase top end yet still have somewhat climbing ability?
The stock gng comes with 12T, but ACS has up to 18T, maybe higher as I didn't check past 18T
I think it would be a simple solution to increase top speed (which is what Im focused on more than off roading)
If you are referring to the stock gng with the chain as the primary, you cannot increase that driver much more than it is. There is no room between it and the large sprocket. They practically touch. Also there is the issue with the actual sprockets themselves. The one GNG supplies is cheap and very thin. Most replacement #219 sprockets that had more than 12T are built too wide to fit the small motor shaft. I know I bought a 14T that didn't fit. Out of frustration, I ended up replacing both stock #219 chain and sprocket on the primary with #25 chain and sprockets. Which provided me with more teeth options.
Now I removed the #25 primary and I'm running LR's belt. And that comes with only 1 driver option for the moment.
Wishes
Oh it didn't fit?? did you use the adapter needed? I think there is an adapter that goes on the inside of the ACS crossfire sprocket.
Maybe you need this in order for it to fit
My mistake you are referring to the secondary, i was talking about the primary. I run the 14T ACS crossfire on the secondary. I don't know what is the largest you can get away with on that side.
Wishes
