bzhwindtalker
Sounds good, 155rpm unloaded does not seem too extreme to me. Now, let's see what It can do on a bike
Also, got some pics?
It almost needs another stage reduction, or a much larger pulley. If you are happy to not pedal along with it, then it is probably ok.
I wonder if you can run it on, say, 24v instead?
It's high, but considering peak power is at around half no-load I'm not too worried. A bigger chainring or dual freewheel and a fixed driver with smaller chain is possible.adrian_sm said:No-load cadence of 155rpm sounds high. But I guess once it loads up this puts peak power out at more normal cadence.
So 48V x 3.6A = 170w up to the first stage. What is the no-load current including the second stage?
full-throttle said:So, @48V the motor alone consumes 115W. Not bad for 3,500RPM. The 1st stage adds another 60W.
I was referring to the 1st stage belt tensioner. I'll post the pictures later.Apache Thunder said:That tensioner sprocket is in fact a standard derailleur pulley.
Miles said:Hmmmm...
I don't like the look of that idler pulley set-up. No wonder it's so inefficient... With a 14t driver pulley, 80t driven and short C.D., I can see why it's needed, though....
I guess they had to add it because they had problems with ratcheting on the driver pulley....adrian_sm said:Then it would have been a compromise based on keeping the existing centre distance, and the available belt lengths. Pity.
Definitely. The sheet-metal still has the slotted holes for tensioning. Guess I could easily modify it with a larger dia pulley..adrian_sm said:So I assume it was a late addition.
Is there space?full-throttle said:Guess I could easily modify it with a larger dia pulley..
full-throttle said:Definitely. The sheet-metal still has the slotted holes for tensioning. Guess I could easily modify it with a larger dia pulley..adrian_sm said:So I assume it was a late addition.
Yes.adrian_sm said:Yep. By ratcheting do you mean skipping/jumping teeth?
