I dunno if anyone still has one of these gng gen2's ..but i do and its still going - sort of.
Got a worn planetary gear, but when i popped it off i found that the post had been sleeved . Post diameter being 6mm & bearing ID 8mm.
My first thought was damn GnG too cheap to build bigger posts or put on smaller ID bearings.
However what i find is the sleeve has 2 pieces. First 3.5mm of the sleeve is steel and the second 3.5mm half is rubber. So the total width of the sleeve is 7mm or one could say the bearing width is 7mm just to be clear.
Does anyone know if there is a purpose to the rubber. The steel sleeves have deteriorated (and my offending gear has worn its seat on the bearing) . I would like to put a 6mm ID bearing on and simplify.....but i cant quite let go of the idea that this little rubber sleeve is adding some give that aids longevity
Any ideas?
Any ideas?
