EstebanUno
- Joined
- Feb 23, 2011
- Messages
- 38
d8veh said:Why go to all the hassle of sending it back if the amp-hours reading is correct? You can calculate watt-hours in your head if you have the amp-hours.
The beauty of watt-hours from the range perspective is that it adjusts to the declining voltage. 1Ah with a fully charged battery yields more watt-hours or measure of work than 1ah with a battery nearing its min voltage. So the watt-hours calculation is always changing based on changing voltage.
Put another way, if your capacity is 10ah, then the first 5 will yield more watt-hours than the last 5. Something to keep in mind when estimating watt-hours from amp-hours.
I have the same watt meter and its watt-hour calculation is wildly inaccurate and inconsistent. Amp hours and voltage are consistent and yield about what I'd expect. Been calculating watt hours, but it's a hassle compared to just reading the meter. Don't like the odds of getting a new one that doesn't have the same issue. Has this same watt hour inaccuracy been reported for the Turnigy version?
