Im fairly new to e-bikes and wanted some help converting my Dillinger Easy Stepover to 48v. From what I have read I am best to update the controller to 48v and think motor should be okay ? I can buy a 48v battery with 15a output that fits the frame so that bit is easy. The controller is stuffed in the frame above the battery and has the case removed to fit so I cannot tell the brand so need advice on which controller to buy. Hoping to get something plug and play that works with the Bafang (Badged Dillinger) C965 display if possible. The specs of the bike are below along with some pics of the controller partially removed.
Thanks in advance for any help.
Daniel
Motor Brand Dillenger
Motor Voltage 36V
Max Motor Power 540W
Drive Type Geared hub motor
Motor Sensors Hall sensors
Controller Brand Dillenger
Controller Operating Voltage 36V
Controller Operating Amps 15A
Controller Nominal Power Output 250W (350W USA)
Controller MOSFET Tubes 6 MOSFET 4110
Controller Sensors Hall Sensor
Daniel
Motor Voltage 36V
