Alsmith wrote
"You can always charge using that old BMS and take power directly from the battery bypassing the BMS- BUT you need to watch your voltage doesn't drop too far to avoid battery damage. This would at the very least get you mobile while the incorrect bms is exchanged."
This is what I decided to do. The other BMS kept shutting off, so I hooked the old one back except I won't be drawing power through the BMS, just charging. I am using a Watt Meter similar to Turnigy but when my battery is fully charged the meter doesn't work until it drains some volts. For some reason it is rated for 60 volts, but can't even handle 51 volts. My battery gets to around 58 volts when fully charged. Rather than shelling out $150 for a Cycle Analyst something with a larger display.
http://www.amazon.com/High-Precision-Power-Meter-Analyzer/dp/B00C596UIA/ref=pd_sim_t_3?ie=UTF8&refRID=1TEAHPVX03N1C99QW5DX
