alpharalpha
I was thinking more of the crumbling edges of back-road asphalt like these:View attachment 1
Seems that Sun re-named its' adult tricycle line to Sunseeker?Xray said:What about a recumbent that doesn't sit as low? http://sunseeker.bike/ The Sunseeker Eco Tad SX is inexpensive, ...
BLUESTREAK said:View attachment 1You can make this out of a schwinn meridian trike.
k9kruiser said:Is there a thread I missed here for those who want to convert a Meridian? This particular thread seems to cover a lot of bases whereas maybe a thread exclusive to the Meridian would be a good solution.
Thanks!
k9kruiser said:My Meridian will be arriving any minute... The gear reduction motor is 650w and since you are dealing with sprockets, both sprockets can be changed to provide whatever gear ratio you need. Doesn't anyone know how much whirring the gear reduction motors make vs. what I am assuming are silent hub motors?
Thanks!
DrkAngel said:
DrkAngel said:DrkAngel said:
Alan B said:Chrome moly forks are not that expensive, dual torque arms and modest power in a steel fork avoids the failure related problems there.
DrkAngel said:
Motor rpm is listed at power but, "power" exceeds needed for noted speed.DrkAngel said:Use calculator and punch in motor rpm etc
See -Speed and Gear Ratio Calculator
Remember though, at low demand, speed will be noticeably higher ...
750w motor output requires:k9kruiser said:Also, when looking at the label on the motor,
36VDC, 750W, 480RPM, 21.6A
Does that mean to achieve the 750W that it needs 21.6A input which I assume means my batteries need to be in excess of 21.6A?
DrkAngel said:Your numbers are off.
You need to adjust factor smaller - bigger to properly calculate.
Just punching in number will not calculate.
Type in number then choose "smaller" then "bigger" to properly register.
Gear Ratio changes as sprocket sizes are calculated.
