eek, on the stove? i did mine outside, i had fun etching and drilling and putting it all together. the only things im going to use from the old controller are the parts, im going to order some 0.1875" copper rod to use as power rails, ill drill holes in them to mount the fets and solder them in. there will be two rods running parallel to each other with three separate parallel ones inbetween for the phases. ill have the metal tab of the high/low side fets facing each other and an aluminum angle piece will get screwed inbetween all of them, the top of the enclosure will be aluminum flatbar, something like 4" wide and 5" long which will screw onto the top of the angle with thermal grease inbetween, both will be 0.125" thick i guess. ill probably make the sides out of plexiglass painted back or something. im not really sure about the size, the pcb is about 3.2"x3.9" its smaller than the brushed one i made. im not sure how the power rails and stuff will fit inside. the hall sensors i was looking at say to use a 100nF cap as close to the device as possible, i was thinking maybe i could use one of those tiny SMT caps and solder them between the to-92 legs or soemthing, i didnt notice any caps showing in the pics of the crystalyte hall sensors, maybe its just the ones i was looking at.
