ElectricGod
Hillhater said:With practice , care, and a few tricks, cells can be separated cleanly without damage.On the subject of replacing bad cells in a LIPO pack. I agree that taking apart an R/C brick possibly means damaging the cells around the failing cell since they are glued or double sided taped together and you have to pull the cells apart somehow.
A few drops of IP Alcohol and use of a fishing line " cheese cutter". , will be a good start.
Trickiest part is separating the tab connectors (crimped or soldered) and remaking them for the replacement cell.
Again, if you choose the common brick sizes, they are so cheap, it's hardly worth fooling about transplanting cells.
..your welcome !Thanks again to who ever it was that told me about hybrid battery solutions.
Just goes to prove,...even a god can still learn something on ES. :lol:
Hahahaha...and while I am sarcastic and irreverant, I also know that I am not a "god" of much of anything.
Yeah pulling LIPO packs apart isn't a huge deal if you do it right. That's why I said "possibly could cause damage" . Well sure if you pry them apart with a screw driver...of course you will damage something!!!
