FredYellow said:I'm not sure what you mean. Do you mean disable the crank chainring freewheel? If so, yes it should be disabled so the cranks can turn independently from the motor.
Ok. I have found the freewheel inside the motor previously, but I think it might be spot welded to a metal tube bit, so flipping it might not be so simple but I haven't spent too much time figuring out what's happening.
Also, not sure if you know this already, but the motor never exerts power to the square taper axle. It is translated through a freewheel to the chainring directly.
