I've played around with a few different BBS0X's, and in general I've found that they're pretty smooth, quiet, quality units.
However, the pulsing/cogging in the lower PAS modes at low motor RPMs is driving me crazy! I find this problem is much worse on the BBS02 - I purchased mine (a 36V 500W) about 6 months ago from elifebike.
I made myself a programming cable and played with the settings. Ultimately, I couldn't do much better than the stock settings, which I'm posting here.
The problem is made much worse if I increase the "Limit Spd(%)" at a lower PAS level (I tried this since Kepler is such a strong proponent of it - not a good idea if you already have pulsing issues!). According to Paul (Cell_Man) at EM3EV, this is just how these units work:
http://endless-sphere.com/forums/viewtopic.php?f=28&t=58780&p=957938&hilit=bafang#p957938
But I've read elsewhere that others have programmed the pulsing out, but I have yet to find out how they've done it.
Maybe it has something to do with "Keep Current(%)"? Ken Taylor talks about that parameter here:
http://endless-sphere.com/forums/viewtopic.php?f=28&t=58780&p=958593&hilit=bafang+pulsing#p958593
My question: anyone been able to eliminate or significantly reducing "cogging" on these units in lower PAS modes? How did you do it?
Thanks!
Henry
Thanks!
Henry
