Hi guys I have another question, I am going to be using a C80100 motor with a 12mm shaft, my question is how do I go about securing the sprocket on the shaft, I will be using around 4KW. I am hoping to use a 9 tooth sprocket from technobots (http://www.technobotsonline.com/sprockets-and-chain/steel-sprockets/tbot-0.5-inch-steel-sprockets.html). Bruno at alien power systems can offer a key in the motor shaft and sprocket but this will be expensive and he does not think the sprocket will be strong enough with the key cut in it. Will two 2mm deep 4mm holes drilled in the shaft for two m4 grub screws be sufficient, and will this weaken the shaft too much?
Thanks
James
Thanks
James
