Hej BlueSwede
I have been experimenting with this, and have discovered the following:
Long Press on M shows 36 right, and next time you long press M it shows 28?
Lets sort this out.
When you long press M and it displays 28, that is the Wheel Size in inch. You can press + and minus to adjust it between 16 Inch and 29 inch.
Lets say you set it to that you have a 16 inch wheel, when you are riding in 25Km/h it will show that you are rinding at much lower speed, (aprox 11km/h)
That means that the speedlimit is not from that place
When you Long press M for the second time, it will show 36 Right? That is the setting for the Voltage of the battery. You can Either set it on 36 V OR 24V
You change between the two by pressing the "Display Light" button, once. You can test it while your battery is almost empty, (so you see the difference, (when set to 24, it will show FULL battery although battery is empty)
Everything you try is at own risk
(detta experimenterade jag fram)
How do we disable the speed limit
No diavelo owner out there?
Lets sort this out.
