lbz5mc12
Okay let me explain. We all know how much of a pain in the butt hub motors and broken spokes can be. Well I think I've hit upon a solution. Why not thread the hub motor into a mag rim? Instead of eyelets on the hub for the spokes, make it a solid thick piece of metal and thread the top of it. Then you just build a mag rim with a hole wide enough to except the hub and thread the hub into the rim. Then you just need some kind of keyed mechanism to lock the hub in place. This would be to keep it from coming un-thread during use but also to prevent someone from stealing it. I figure you could use mag rims anywhere from 20" on up to 29". I don't think it would work with a 16" wheel unless it's a small geared hub.
This would also allow the user to easily switch out his/her rim sizes without having to completely rebuild the wheel. Just order a new size rim, pop the hub out of the old one and thread it into the new one. Go from building a wheel that could take hours down to just changing it out in a few minutes.
Yes I know that hub motor cases are built out of 2 separate halves. The manufacturer would have to fully assemble the hub and when it's sandwiched together, thread the top of it and "mark" it so that if it's ever taken apart it gets put back together so that the thread lines up.
The rims could be built out of aluminum, titanium, carbon fiber etc. No more broken spokes and tedious wheel builds.
Sorry to edit my post but I just had an improvement idea. How about making the hub into a big freewheel? Brushless hub motors cause drag, what if the ring of threads inside the mag rim were a big freewheel. You reverse thread the hub so that it threads in in the direction it drives. When the motor's engaged the wheel spins and when its not the mag freewheels over the hub so there's no drag from the motor.
