Endless squarer
- Joined
- Jul 18, 2016
- Messages
- 21
I had shorted out my last controller and obtained a new 48V 1500w sine wave controller. After connecting everything, the lcd worked fine however the motor would spin. I can spin the motor at a walking speed from my lcd and that worked fine however the throttle wasn't spinning. After close inspection I realised that the 3 throttle wires from the controller were in a different configuration to the 3 from the throttle. I had connected the speed sensor (white wire) to the negative terminal (black wire) but the positive terminal (red wire) was connected correctly.
I rewired the throttle wires but the throttle still does not work.
Is the problem in the throttle or is it in the controller? The controller seems to work fine however.
The controller also has a lot of extra cables which I do not have such as cruise control, pedal assist. Could this be the issue
