RollingGecko
- Joined
- Jul 14, 2015
- Messages
- 110
Hi,
I've now build an Arduino based Nunchuk replacement with nRF24 that communicates with the VESC over UART an takes also the measured values and gives them back to the remote. Currently I use 2812 to indicate for example voltage state. Later I will add a OED. I will soon publish everything.
I just added a small peace of code to the commands.c message handler. I added a message, that sends the nunchuk data and pasts them the the nunchuck app. So far so good. In the bldc tool I can see, that it reads the information of the y-axis fine.
My problem is now, that the motor starts spinning after the deadband with full throttle. There is no regulation possible. I don't think, that it is caused by my implementation. As I sad, on the bldc tool I can see a good interpretation of the y-axis joystick position.
With PWM and direct current setting over UART it works fine.
Any ideas?
Regards
Andreas
Any ideas?
Regards
Andreas
