I am new to this forum and have been doing much ev research. I am working on a heavy hauling trike that I intend to power by human power and 5305 front hub motor with disk brake. My planed traction pack will be 55Ah@72v nom. w/ AGM's. I am building it to have long range-duration capability, as well as, power for pulling load(1000 lbs. gvw) up fairly steep but short distance grades. I also would like to be able to reach flat road speed of at least 35 to 40 mph sometimes, although most use will be at low speed(under 25 mph) and mostly flat. I have looked into controllers: crystalyte 48a@72v,clyte,ecrazy man but think the power requirment may over stress all of these, even with standard mods. Can anyone tell me if it is possible to adapt a kelly 72201 to the 5305, and if yes, then how? I've read volt-amp combo as high as 100v and 125amps working with this motor. The 72201 is 120a cont. 200a max. /w regen. and is made for perm. mag. motors. Many thanks for any help with my design. Weight of unit 185lbs, pack 231lbs, controller,charger,wiring and 12v batt.~50lbs, + payload up to 600lbs. I plan to pedal most of the time and I am gearing with this in mind. I'm 6'6" and will be turning 210mm cranks. I am a strong rider and hope to offset consumption during low demand periods but realize my input percentage is low during the high power operation. I also intend to use in cold weather, under freezing. I have not seen any other craft like this, so all help is great... Thanks all...
