Hello, could you please help me? I have a problem with my Kelly KHB12401. I have a homemade 18kW BLDC motor. Motor voltage is 100V so the current should be 180A for 18kW power. I have eight 12V Pb car batteries 80Ah as a power supply. My problem is that I am not supposed to put into the motor more motor current (in the three motor passes) than 90A and something about 40A battery current(cable between battery and controller). I have measured the current values with my clamp Ameter. My controller just doesn't provide enough current. So the motor has really low torque an it starts to shake when the load is too high. It seems me like the controller doesn't supply enough current to the motor. What could be wrong? I have an original Kelly single control box. In torque mode the torque and the revolutions of the motor increases in the first half of the potentiometers way and the battery current is max around 40A. It is quite the same at speed mode. The revolutions increase in the first half of potentiometers way and the max battery current is around 30A. I have already checked my motor and controller wiring resistance and it seems all right. That's why I assume, that my controller setting is wrong. My motor current settings is 100% and my battery current settings is also 100%. My throttle control settings is 0-5V but I have already tried 0-5K settings with no change. What can be wrong? Can you please help me? Thank you for some suggestions.
