stancecoke
- Joined
- Aug 2, 2017
- Messages
- 1,820
Obviously the board revision KT-SVPxx uses a different gain at the OpAmp. So we have to use a diffent calibration factor in the code.honya96 said:50A set at tool blew my 8A fuse so I replaced with 20A
I guess, the R17 is different from 10k on your board.
honya96 said:Does not start the motor with a bit of throttle while icon is showing it should run.
I think this is caused by the offset to negative zero current value, we implemented yesterday to make the motor stop faster.
regards
stancecoke
