I have just received one of these controllers from BMSBattery (Ecitypower) for my next project. It has some nice features: Cruise control, speed limit and 3 speed switch connectors. My last one was similar with cruise control but not the speed limiter and 3 speed switch. I like the cruise control, but it's difficult to set. You have to keep the speed/throttle constant for about 5 secs, which is difficult on a bumpy road and it gets cancelled each time you use a brake or the throttle. Ideally, I want to set my bike to cruise at about 12mph using the pedal sensor. My friend has a speed limiter switch on his 9FET Ecitypower controller but it doesn't work on the pedal sensor unless you hold full throttle which seems a bit crazy. So here's my questions:
1. How do I wire the three speed switch? I have one with three wires and there's three wires to the controller. How exactly does it work because there don't appear to be any components in the switch? Does it matter which wire goes where?
2. Does anybody know the logic of the 3 speed switch? Does it set 3 speeds for both pedal sensor and throttle? I've heard that on some controllers the medium setting gives higher speed than with it disconnected!
3. Does the speed limiter work on the pedal sensor and throttle, or only with the throttle open - like on my friends bike?
