Hey Guys,
In an attempt to keep from clogging up the drive system thread, I figured I would start a new thread about options for braking while using the disc brake flange as a sprocket mount.
Here is one possibility. I opened up my Avid caliper to the max and it fits (with room to spare) around this #25 sprocket! So, I could use a "Sprotor" (sprocket/rotor) arrangement if I am willing to run a #25 chain. I am not sure that small chain will be enough. But, if I go with a large enough sprocket, the chain loading will be lower and the "Rotor" will be larger for better braking. So, maybe a 8 inch Sprotor?
The chain does have to go around the caliper.
Lube is not a big deal as you can use many different types of dry lube. Also, if minimal normal oil is used, it does not move from the teeth down the sprocket face.
The pads contact the disc just below the teeth. So, this would, in theory, work fine.
Oh, heat is not much of an issue on bike disc brakes
unless high speed and long braking distances are encountered.
I think it could work. Again, I am concerned about #25 chain strangth.
I guess some testing is in order!
Let's remember, left side drive is not a problem, it is brake options when using a left sider drive that is the issue.
My recumbent has rim brakes on the rear, so no problem there. But, I prefer disc brakes. At speed my rim brakes stink.
My mountain bike has disc brakes front and rear. I have a machineshop. So, for me, it is not a problem. But, I am trying to figure out the least painful left side brake option for those without access to a shop.
Matt
