Oooo, good question. At this point I've got about $1000 in the pack. It does seem like a high price, but it was an upgrade for me from the foil pack type of LIFEPO4. I used the foil pack for about 1000miles before I started having problems with the foil tabs breaking off. I repaired my foil pack a few times but it was become a real PITA tearing the pack down every couple weeks to fix more torn foil tabs. Those tabs are just tiny, and very hard to work with. They don't take solder very well and leave you frustrated. Frankly, the roads I use the bike on are very rough and I hit some bumps that can be bone jarring. At the speeds I was travelling it just beat the ping pack I had to death. I know my situation was pretty extreme though. I'm sure many people are fine on the foil packs.
These BMI batteries are currently pretty pricey if you look at just the sticker price. However, if you consider they are tested to last over 5000 recharges and offer a very solid construction with bolt terminals and tremendous current capacity, then in the end they offer the best value for us e-bike hypermilers. I plan to run them at least 5-7years (maybe considerably more), so they will end up at much lower cost per use than the alternatives. I've already go about 500 miles on them. So, I figured the investmen was well worth it. I'll save around $40,000 over the expected life of these batteris compared to the gasoline I would use, so what's a $1000? That's really what I was looking for originally with LIFEPO4 was a way to save money over time. I built the case to really protect the batteries from any abuse and make them last as long as possible, but I'm sure I'll never have the foil tab issue with this pack. So far this pack is the best I ever had. I'm very satisfied with it and the price I paid for it.
