oddjones
Hi all,
Well I pulled my JimmyWu 36v 10Ah non-functioning pack to pieces and I got lots of blue Valence saphion IFR-18650EC cells.
They (were) grouped into 12 strings of 7 cells welded in parallel with thin (read sharp) tin strips.
The readings I was getting from the terminals of my BMS (prior to disassembly) were as follows
[pre]string reading value
1 3.1v 3.1v
2 5.7v 2.6v
3 7.1v 1.4v
4 10.2v 3.1v
5 13.4v 3.2v
6 16.5v 3.1v
7 19.6v 3.1v
8 22.7v 3.1v
9 23.9v 1.2v
10 25.0v 1.1v
11 26.1v 1.1v
12 27.3 1.2v[/pre]
SO: I split the pack up into good strings of cells and bad strings of cells. The bad strings I then cut into individual cells to see whether any were salvagable...
It turns out that from the bad strings of cells there's not a single cell which reads over 2v.
Question 1:
Is there any point whatsoever trying to "rescue" these bad cells? I have a Nokia 5.7v mobile phone charger hooked into a jury rigged single cell frame, but I've not connected it to a cell because I don't know if it's a dangerous thing to try.
Question 2:
I have 49 good cells and a BMS which is set up for 12 "strings" of cells - by my reckoning that'd give me 12 strings of 4 cells or about a 5-6ah battery. Is it that simple? - my daily commute uses about 2ah (each way) so this battery should just get me there and back.
Question3:
I'd be wiring the battery in serial with my other (working) 36v 10ah pack through an infineon controller fitted with 3 way current switch. I've been told that my Bafang motor won't handle the full power of a 72v system for long so intend using it on the "middle" setting of my current switch, which to my (limited) understanding offers the equivalent of a 48v battery. So I assume the actual load on each battery would be less than I'm currently using by running the "high" setting on a single 36v 10ah battery.
Does any of this make sense?
1 3.1v 3.1v
2 5.7v 2.6v
3 7.1v 1.4v
4 10.2v 3.1v
5 13.4v 3.2v
6 16.5v 3.1v
7 19.6v 3.1v
8 22.7v 3.1v
9 23.9v 1.2v
10 25.0v 1.1v
11 26.1v 1.1v
12 27.3 1.2v[/pre]
Question 1:
Question 2:
Question3:
