LightningRods
Another thing to consider when choosing a belt drive system is what tooth counts of sprockets you can find. With the particular supplier that I use, the smallest M5 driver you can get is 18T. The smallest M8 driver is 22T. To get a 5:1 reduction you'd need a 110T driven. A 110T M8 has a pitch circumference of 880mm or over 34 inches. That's 11 inches across!
If it isn't obvious to readers Matt uses M5 pulleys in the primary stage to get a lot of reduction in a small space and then M8 in the secondary stage to handle the slower speeds and higher torque.
