Its hard to get a lower inductance layout than direct dice-bond wire-dice.
http://ixapps.ixys.com/Viewer.aspx?p=http%3a%2f%2fixapps.ixys.com%2fDataSheet%2fMTI145WX100GC.pdf
Your topology exploits this chip very well. It would be ideal for pretty much every ebike from 250w to >5kW ebikes just depending on if you wanted a match-box sized few ounce passively controller for roadbikes, and a giant fan cooled CPU heatsink or something for people trying to get >10kW or whatever, but everyone could use the same tiny Lebowski control PCB, and you just vary the caps and heatsinking and maybe leave spaces on the PCB to solder in the small current measurement chips and the biggest allegro or whatever.
Same PCB board and code and tuning software makes you a plasma breathing hot-rod ebike controller with better than sinus control and no sensor BS needed for precise torque control, or a matchbox sized 250w 36v controller setup that would survive forever with a bare minimum of caps because of a high safe voltage ceiling and low currents and essentially no need to even heatsink it at the currents in a 250w system. That would be like the God of all EV PCB's. A single one already is the best sensorless ebike motor control system in the world that I've ever even heard of at any price. With one PCB you could offer that level of control in very easy, simple and DIY friendly to assemble (bolt one already isolated package to something that serves as a heatsink, solder on already professionally reflowed lebowski control boards using modern super fine pitch SMD components, with just a number of big (and small) plated through holes. If you're making a tiny controller for your road bike, maybe stuff some tiny polymer cap footprints for use with up ~30v-ish stuff (which is huge IMHO, including 90% of RC and robotics and multi-rotors etc).
http://www.panasonic.com/industrial/includes/pdf/POSCAP_NPI_Sheet.pdf
Along with the usual arrays of various different sizes of caps for wide freq coverage transient absorbing, and TVS diode footprints etc. All the stuff typical ebike controllers don't do to save $20 in premium quality components or design, and as a result they fail when pushed.
You could offer both better performance (smoother, sensorless, perfect torque control, easily adjusted/tuned) than anything else I've ever seen, and cover a very wide range of ebike power needs all with the same tiny board we buy from you already populated to the level where it's just missing the heatsink and non-SMT caps and current sensors. Then how you finish the build becomes the big factor in its size and power.
Gang 4 of the boards together built up for power and maybe have a 50hp drive. Maybe 8-20 of them power your car and enable awesome high power performance and efficiency, but at non-lethal voltages. Or use one with a tiny heatsink positioned in the propwash of multi-rotor on a board populated with kick ass solid state caps.
Maybe leave the expensive parts unpopulated in the isolated daisy-chainable coms bus so it only adds that cost to people who are going to gang up groups of them, because I think most applications won't need it, that single chip is tough enough for really any non-racing ebike needs if you cool it, and its an easy to cool package.
