MonkeyWrench
So, I'm considering what motor to use for my second bike build (first was stolen last Friday )
Comparing the MAC 500/1000w (8 turn) from em3ev http://em3ev.com/store/index.php?route=product/product&path=40&product_id=52
to the 9C 500w clone (970 RPM @ 36v) also from em3ev: http://em3ev.com/store/index.php?route=product/product&path=40&product_id=111
I'm coming from the yescom GM 901 motor, which rocked & seemed very capable of handling much more wattage than the 12s/44.4v Lipo and 30A controller was dishing out. Road speed on the flat with the GM 901 running 12s was ~30 mph hot off charge. However, it was a lot of motor to haul around if I don't need that much thermal mass. My goal for the new build is to top out at 35+ mph running 18s.
For purposes of using the ebikes.ca simulator Am I correct in assuming the MAC 8 turn ~= BMCV2Speed and the 9C,370RPM ~= 9C2806 ? I was mostly trying to match up the kV ratings.
The ebike.ca simulator indicates that (if I am correct in my assumptions above) both motors will get me there speed-wise. BUT the MAC has much more impressive thrust while accelerating. Here is the screen output comparing the two:
Now, I realize the geared MAC has less heat capacity than a direct drive, even the comparatively wimpy 9C clone. I am tempted by the oil bath approach for both cooling and corrosion resistance (planning on commuting in the winter- in Seattle).
I'd appreciate it if someone more familiar with the motor choices could confirm my assumptions on the simulator settings.
Thanks!
~Matthew
EDIT: ok, found one of neptronix's youtube vids that confirms the MAC 8t is equivalent to the BMC-V2speed http://www.youtube.com/watch?v=UD_K_TRGcs4 Yeah, 45 MPH is a bit much!!
Thanks!
~Matthew
