Hello everyone I build a few boards and had some failures but i am in the process of building a mountain board with matrix pro trucks but i have a few questions. Looking at this website
https://www.hobbywarehouse.com.au/articles/how-to-match-esc-motor-lipo-battery-rc-car.html
it tells you how to get the right spec for correct battery to esc to motor.
Granted im still very New to making my own stuff.
My Build plans to be 8s 15ah 35c battery with 2 monster mamba lx 2
Gearing 12/72 or 16/72 on 200mm wheels. tacon 245Kw motor. belt drive 390-5m-15.
Lets start this process
Tacon 160 http://www.hobbypartz.com/96m608-bigfoot160-5335-245kv.html
2700 watt divide by 14 multiply times 8
2700/14=192.85x8=1542.8Watt motor for the power im putting in it correct
Motor Watt divide by volts
1542.8/29.2=52.83 max amp draw?
for the battery i am going to make my own Time for Math
Fortunately, there’s a quick calculation you can use to work that out as well. If you have the battery’s milliamp (mAh) rating and C rating (if it is given for both charging and discharging use the discharge version), then you can calculate the amperage a battery can safely have pulled from it. You simply multiply the mAh rating by the C rating, then divide the lot by 1000: mAh x C = A.
So with that in mind im building a battery pack LG Chem 18650 HE4 20amp current discharge 35amp max discharge
More Math
15000mah x 35amps =525000/1000=52.2
so that would be building 2 8s3p 1 8s6p pack to make 15ah to make the most of my set up correct? I don't have all the facts about all the parts but there is a sweet spot and I'm trying to land directly on it.I am reading alot of stuff about battery. I just want to make sure i make a monster mamba xl2 Mountain board that can handle any terrain up or down that have the best parts possible with the best performance and longest life to beat any stock. Money is not an issue. There is a lot of info out there and very few helpful/useful. I am making my own starting from Design stage which is done. if i have anything wrong please be nice about it. I have Free range access to a mill and water jet machine. Please look forward to my Mountain board build. and Please Be Nice and Helpful.
More Math
