cwah
subscribed
What is the model? And are you doing lugs or unions or...? 8)Alan B said:I'm enjoying a hydraulic crimper, they are available from Harbor Freight or eBay.
Kingfish said:I am considering crimping over soldering on the interconnections for my battery harness which will be a mix of 6 and 8 stranded. I’ve narrowed to a couple of choices. Sadly the WestMountainRadio crimper only handles up to 8 AWG; pathetic considered how much it cost. Alternative candidates are:
- Pro-Crimper by Prs-Kit + Lunar series Die Set for 10-6 AWG (about $46.26 before shipping)
- E-Z Red B790C Hammer Indent Crimper Tool for 8 to 4 AWG ($22.50 + shipping)
I don’t plan to do a lot of crimping in my life, but I need something better than trying to solder big wire gauge together.
Thanks in advance, KF
cal3thousand said:BTW... that swage tool is for up to 4/0 AWG... much bigger than 4 AWG
icecube57 said:I not being smart or anything... if someone is doing to shit like that with my harness its their own damn fault if it fails. They are purposely seeking failure... it falls way out the realm of realistic usage requirements.If this was for fencing using steel cable that requires it to hold that wire under extreme load it would definely need to be tested in such a manner. But for our use a good tug test on each wire should be more than enough considering i know my pulling force exceeds 500+lbs .
Kingfish said:IceCube: Lakewood guy, gotcha - he was high on my probable hit list I shall do it!
Ice, where did you get those copper sleeves? How do I spec that? Are they like these: Copper Crimp Sleeves?
Crimp Test: That's over the top, but fun hehe :lol:
Diggin' it! KF
cal3thousand said:Kingfish said:IceCube: Lakewood guy, gotcha - he was high on my probable hit list I shall do it!
Diggin' it! KF
Someone here previously pointed out that Home Depot carries them, I can confirm as I picked up a box for about $6 for 50 count last night. They are the 8-14 AWG copper barrels. There's only 2 sizes in the aisle, it's located near the zipties
Alan B said:If the crimper is too small you know how to fix that.
