donn said:Clearly, there are good things about any of the options. I just want to mention that I see a fair number of "cargo" bikes around, with 750W direct drive hub motors. We have hills here, 4-5% is more common but there's some 7%. I can't guarantee that everyone with one of those bicycles actually uses it to carry heavy loads. The model I usually see has an advertised weight of 73 lbs, and payload capacity 350 lbs. That payload isn't going up a 7% hill, but your 300lb total weight should be doable under 750W.
I'd guess 750W might be good enough. The street in front of my house is 6%, which is pretty mild for my area (my daughter and I had a tradition of racing up the hill after our bike rides when she was growing up). My regular route from the bottom of the hill to the top, which is about a mile, is 9%, with the steepest sections being 16%, but only for 4 or 5 block stretches. With 230 lbs total weight, the motor probably averages somewhere around 500-600 watts and maybe 800 watts on the steep parts, with me pedaling of course. 750 watts with 300 lbs on a 7% grade sounds about right.
