robocam
- Joined
- May 29, 2014
- Messages
- 773
Is the least expensive option $1579 AUD (0.76 conversion is $1196 USD)? And that's without some of the optional upgrades.
It looks like they did some nice stuff to it (although some arguably unnecessary depending on your intended use). But it only takes a little to make the Cyclone reliable. What voltage are you planning to run it at? Are you going to run the stock controller unmodified? How fast do you want to go? How do you plan to use your bike? Commuting? Technical trails?
I wouldn't say the Cyclone is the best because the BBSHD is really quiet, which is why I'm seriously considering changing from a Cyclone 3000 to the BBSHD. It depends on your needs.
Megsy73 said:...So after all that the best is the new C3000w cyclone ?
I just saw online some details of the new AFT C3000w kit, this would have to be the best C3000w kit ?
http://www.aft-ebike.com/c3000w.html
It looks to have stronger mounting brackets, kelly sinewave controller, ceramic bearings and some other things to reduce the weight . It looks pretty good, high power, low noise and low weight...
