batteryGOLD
As the title says, I built a battery pack 13s5p using LG MH1 cells salvaged from scooter batteries. I tested each cell on a Opus battery charger (on the 1A discharge setting) and they were all showing around the 3200mAh they are rated at, so it should be a 48V 16Ah battery. I built it to run a smaller bike with a 500watt geared front hub for a friend to ride and it worked well, although we never pushed it to its limit. I recently swapped my 1500w rear hub to a full suspension bike where there is no room to mount the big 52v20Ah battery I was using before, so I decided to give this battery a try.
What I am finding though is that I am getting far less range than with my bigger battery, like less than half the range, when this battery has 3/4 the Wh. (1040wh with the 52V triangle battery vs 768 Wh with this battery). The controller starts cutting out when the battery is still showing a resting voltage of 47v, according to this chart I found there should still be some capacity left.
Sir, I see you have at least two problems with your 13S battery
problem#1 --> S elements debalance
max is 4,20V (top cut point) & min is 3,93V (this element will make bms cut soon than others) --> soo it seems at this point U already lost about 25-30% capacity, so your estimated available capacity is about 16Ah x 0,7 equals 11,2Ah available.
problem #2 --> maybe reused cells with higher internal resistance mixed inside pack, you could have a week element anywhere from 13S elements. tha weakest link..(maybe #5S element or other or multiple elements affected, wish U luck to find iT)
the battery minimum voltage cut point should be 2,7V x 13 equals 35V , but your system cuts at 47V.. soo thats a huge difference
estimate capacity available at your battery calculate 47V/13S equals 3,62V (this means a 45% SOC state of charge ), soo thats 45% of battery unused , doin math 16Ah x 0,55 equals around 8,8Ah available, U could classify your 13S battery as a 9Ah battery grade B--- (I dont know letter grade scale, sorry..)
PS: problem#2 is dominant , so from 11,2Ah (problem #1) ,U only get ~8,8Ah
tha best ideia is simple, just build a new pack with new cells.. just sayin.. Do you want to have a low capacity battery and a risk of overheat or other risks?
"real good joke" consulting service TM,
have a nice day!
