ElectricGod
More pics...
This is the back end mostly reassembled. I'm still waiting for some 10-32 hex head screws and the wheel sprocket. The screws secure the brackets to the back wheel assembly All the holes through the back assembly frame are tapped for 10-32 and then I'll also lock the screw ends down with a 10-32 nut inside the frame. I little blue locktite on all the threads will take care of any other screws working loose. I rerouted the wiring a little so it stays up and out of the way of the tire.
The bracket that came on the caliper was so close to what I needed that I went ahead and used it as is. I needed a couple of spacers to hold the caliper in the right position so I used an axle spacer and cut it to the length I needed for the two bolts that mount to the back frame. One of the bolts goes in the space where the old bracket bolts went and the other fits in the front most section of the left drop out. It should work pretty well and not get in the way of properly tensioning the chain.
The motor bracket has been upgraded a little. The new bolts are 8mm stainless bolts and a bit longer than the older/smaller ones. With the longer bolts I am able to add washers to both ends of the bolts so that the paint doesn't get scuffed up when the bolts/nuts get tightened. In the second picture you can see the extra aluminum plate I added to strengthen this side of the motor bracket. I bent the battery box mounting arm on the sprocket side to clear the motor sprocket. You can see that the sprocket clears quite nicely. Unfortunately, to change out the motor sprocket requires pulling out the motor bolts so the motor can be slid over. It's a bit of a pain to unbolt the motor, but realistically how often do I change out motor sprockets?
The back end assembly sitting upright.
