dogman said:
Ok, so you still have a motor. It's just a battery problem. That means running that motor at 72v could be a possibility, with a 72v controller of course. Sadly, it may not help as much as I thought, if you have a light on the hill. But even from a dead stop 72v 20 amps is still a solid 1500w of go power. More watts helps for sure.
I appreciate that you're trying to help me save some money here, however that's not really a concern. My primary goal here is to do a completely new build, optimizing every part of the system (frame, brakes, motor, battery, etc) to a level which I deem more optimal. I'm not going to go out and buy a $3,000 carbon-fiber frame, however I have no problem at all spending an extra $400 to really optimize the motor.
Switching from my existing motor to a geared MAC 10T motor will have the advantages of lighter weight and complete freewheel ability, and from everything I've read and seen thus far, it would seem that the MAC is also a much better choice for hill-climbing. If there's a specific reason why some other motor (even the one I have now) might be superior to a MAC 10T in terms of performance then I'm certainly open to this, however the savings of a few hundred dollars does not weigh into my thinking on this. I have no interest in cheaping out if it means compromising the primary goals of the build
o00scorpion00o said:
How about selling the existing kit ?
At the moment, I am attempting to pursue a refund from Amped on the kit as a whole, with the desire to part ways from them on good terms. Up to now, our dealings have been quite pleasant, and I'm hoping that we can resolve this issue amicably. If that succeeds, then great. If not, then I will probably do exactly as you suggest- fix the BMS, downgrade the controller, and then sell the whole thing. Either way, I don't plan on any part of it winding up on my new bike.
And the geared hubs allow the motor to spin faster anyway making them more efficient for climbing.
Hence my strong desire to eliminate the motor I have now from the build.
If you had to get a new battery anyway then get a new motor, the 48 volt may be just fast enough for you in the 10T, and cell-mans battery will be more than capable!
The mac kit would make the bicycle feel a lot more like a bicycle, if you like to pedal as I do, then it's the best choice.
The mac kit should also eat hills much better.
This is what I'm hoping. At this point, I've really just come down to whether the 10T is the best choice for a motor, and if so, what voltage I should run the system at.
Based solely upon the video that was posted earlier, my impression is that the 10T is adequate and that I don't require the 12T. So for the battery, it comes down to whether I use Cell_Man's 52v "triangle" battery, or trade Ah for voltage, perhaps with a 20s 4p arrangement. That would give me the sane number of cells, and thus the same weight, with 65v @ 9.2 Ah. Given that my 36v 10Ah battery has never been problematic in terms of range, this might be an appropriate solution.
Again , I strongly recommend a temperature sensor in any motor, especially for hilly areas, then you can adjust your controller for more power if it's not heating up much.
I'll do this. I assume that some sort of PTC thermocouple is used- any suggestions on an appropriate display gauge?
