litespeed
So I have a 14KW MaxE/QS 205 3.5T 17" Vector framed monster which I love. I ran it this year off of a 20s15p Koinion pack I built and it did great except when riding it as hard as I like. I am peaking at 196 amps and get big voltage sag after 20 to 30 seconds on a fresh charge. After 30 mins into a ride I hit low volt easily with a lot of throttle. So a couple questions come to mind.
1) Would it make sense to go to 22s to lower my total current? I have read more times than not that 20s is the sweet spot for the MaxE but thought I would check to make sure things haven't changed.
2) would a 20s12p or 22s12p 30Q or go to Multistar 20s or 22s 32 amp pack made up of 16000 packs?
I'm sure long term the 30Q would last longer but they will cost about $200 more at today's rates on the Multistar batteries but I could then swap to new technology batteries sooner since I would assume that the multistars would only be good for 300 or cycles. Weight would be about the same or possibly the 30Q would be slightly less with slightly more amperage....36 vs 32 amp. I have thoughts of going to a QS 273 in an 18" wheel ( to do a 1 cross and a 3.5 wide tire ) one day so would like what ever battery I go with to work with this as well. That would mean 150 amp continuous and 250 amp peak.
Thoughts?
Tom
Thoughts?
Tom
