I did 11.7 miles on fresh batteries this morning. I have a 12S1P - 8ah battery. I started with 49.5v and ended with 45.2v. I then went about my day doing a bunch of sh*t that's no fun. I get home, rest a little and get to work.
The batteries and controller are out of the back pack! And the throttle is no longer tied to the handle bars. I even installed the brake levers so the motor cuts off when I hit the brakes! I'm amazed - that's progress !
But it sure is work in progress - look at it - it's a disaster! And knowing me - this is good enough! I'm the type of guy that if it's urgent, it gets done pronto. If it's important, it will probably get done soon. But if it's neither urgent nor important - it can take ages to get done. :|
It's ugly and awesome at the same time!
So, what do I do now? Easy choice - I go for a ride with the same battery (same charge) from this morning. I figure I still got 3.2v until LVC ... that's PLENTY. I think I went at least 5 miles and then the motor cuts out
. I figure LVC I guess? So I don't hit the gas for a while and pedal. Then I hit the gas - nothing
. So, I'm thinking may be once LVC is hit the controller is just shut down until a battery swap occurs. So I find a bench, unplug the battery, and hang out for 5 minutes. I figure the battery will come back a little - this will make the controller happy enough and I'll be able to limp home. But all I get is a tiny surge - just enough to put a "YES!" in my mind. And then nothing again
. So, I ride home -- wow, riding a bike is hard!
I check my voltage and wa-la, it is LVC ... I'm happy again. Everything seems good. Controller doesn't let me ruin my batteries - yay! THANKS wesnewell - you da man! You called it every inch of the way - I hope I'm not overboard here - but I think your advice got me to make the very best choices I could in terms of value and performance - THANKS!
I need to get my $4 volt meter on my handle bars (thanks again wesnewell!)
So now my battery pack is in it's new home -- my very first charging house
Yes, I'm a geek. But I'm a hell of a nice geek - with a pretty sharp sarcastic sense of humor
