bikerpete said:VasiliSk said:You can setup port to CL1..5 to 'Config Load 1'
Thanks Vasili.
Unfortunately I don't understand your shorthand.
When you say Port, what do you mean?
And CL means what?
I see Hot key 1-4, IO 1-8 and CAN 1-16. But no "Port" and no "CL".
Feeling a bit dumb here.![]()
Nixunen said:If you want to set that load config button example in display most right button, then go to display settings and there buttons setup. Set hotkey 4 type to normal and hotkey 4 func. to can_4 and save settings. After that go to controller settings, and there I/O configuration. Find Can port 4 and set there CL1. And save settings. Now when you press display button (first in right) it load config named ncconf1.cfg in your sd card (you need to made that file before).
Using that method you can setup more buttons to load more config files. Or use external buttons if you don't want to add those in display buttons.
I recomended to join Nucular Telegram group. There you can get answers much faster than here.
Thanks for sharing, looks amazing!VasiliSk said:Here is my attempts on nucular 24F based karting:
VasiliSk said:6F is unknown yet. I want to make it on new technology but certain chinese mosfet manufacturers are stubborn and dont want to make new package design)
[youtube]TFdnVHtLtAw[/youtube]
VasiliSk said:Hello electric geeks!
Got some news, for everyone who missed we updated display. It is also in stock now, you can order new one any time on website.
More bugfix updates for controller, before adding new functionality:
Controller v0.8.9
This update fixes issues with the reverse function of the previous release and also some problems with recently made controllers. There are known issues with starting under high currents that will be investigated later.
Also added 'load default' option by section, now you can easily reset system settings and keep all control settings.
Ok, any rough timeline on the 24s bms?Unknown yet, after BMS and 6F
