I already read and tried it weeks ago, that's why I asked you if you meant "Throttle and brake curves setup".. It doesn't really help because I already turn the throttle to 100% in the very beginning of a ridePITMIX said:You should read the manual !
https://docs.nucular.tech/doku.php?id=en:controller:setup
In "CONTROL" and in "Throttle and brake curves setup" you can set the percentages of acceleration and braking on 6 levels.
generic hub motor probably about 3000w, 60v 30ah c8 Samsung 25rVasiliSk said:HEAD what is your bike?
HEAD said:can you have motor braking without charging the battery, I think that the braking current is too high for my pack but I still want strong braking power
cheers
PITMIX said:The only time braking power can be a problem is when you charge the battery over 90%. If you keep a sufficient margin that's fine. You have several braking intensity adjustment that of the braking phase intensity allows you to adjust strong braking. I have 250A of phases for braking, and it never goes up to more than 80A at the battery.
makes senseNixunen said:HEAD said:can you have motor braking without charging the battery, I think that the braking current is too high for my pack but I still want strong braking power
cheers
You cannot get motor braking without charging battery (using Nucular). There should be something to waste that energy. Like huge resistors which burn energy at heat.
PITMIX said:The magnetic brake does not unbalance the battery.
It's your cells that are too weak.
The brake mode must be set to 0% Throttle. This adjustment is to be made for the 3 speeds and also for the general control mode.
what do you mean? This is the Nucular discussion thread right?Talon said:Beautiful diagram ...... Nucular Electronics are the way to go with any technical questionsbefore asking here :wink:
Don't you have something better to do than micro message me for nothing? Go away dude :?john61ct said:No idea what that means
