want to build
- Joined
- May 18, 2018
- Messages
- 291
hi
I recycled cells from makita drills
when liberating the cells, i dremeled to deep .
1 Can you look at thoses cells to si if it looks safe ?
2 To be sure there is no shortcut between the positibe pole and the negative enveloppe, i tough about adding a bit of this glue to avoid problems is it a good idea?
my motor controller only require 7 amps to work and the place i look my bike is visited by thiefs (downtown) so i decided to build a mini pack just for small support. ithe mini pack is 13s2p. each paralel group is made of 1 vtc3 and 1vtc4. see below
3 what do you think about that? the motor will be xiongda 2 speed hub motor.
tx
4 one of my big fear is that when i solde copper on the positive tip, tin drops (over dorps) on the side of the positive pole and make contact with the enveloppe negative. how to avoid that?
3Ah Makita BL1830 :
10 x Sony US18650 V (LiMn 1600 mAh, 7.5A continue ; 15 Amp burst, 18-30 mOhms DC)
Original Makita spec for the pack:https://www.elektro-online.de/img/shop/ ... bl1830.pdf
4Ah Makita BL1840 :
10 x Sony US18650 VTC4 (LiMn 2100 mAh, 30A continuous; 100A very short burst ; 12 mOhms AC)
original specs:https://www.powerstream.com/p/us18650vtc4.pdf
glue
https://www.aliexpress.com/item/Bicycle-Repair-Tool-Bike-Tire-Repair-Glue-Bicycle-Inner-Tube-Puncture-Repair-Cement-Rubber-Cold-Patch/32956475304.html?spm=2114.search0104.3.71.46717bfarz8rBG&ws_ab_test=searchweb0_0,searchweb201602_6_10065_10068_10130_10547_319_10059_10884_317_10548_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_537_536,searchweb201603_53,ppcSwitch_0&algo_expid=75673b63-8a80-4298-bef0-01ff47ab6f7f-10&algo_pvid=75673b63-8a80-4298-bef0-01ff47ab6f7f&transAbTest=ae803_3
motor
https://www.elecycles.com/xiongda-2-speed-hub-motor-coversion-kit-36v-48v-250w-350w.html
tx
3Ah Makita BL1830 :
4Ah Makita BL1840 :
glue
motor
