Overview: best rectifiers for charging (voltage mod) - Eltek/Delta/Huawei/Emerson/Vertiv
Tomblarom
I couldn't find anything like this and made this for myself to compare common telecommunication PSUs / rectifiers. Trying to update this frequently. Used datasheets attached. Enjoy!
Eltek
  • CAN / I²C: https://endless-sphere.com/forums/viewtopic.php?f=14&t=71139
Code:
  Model        Power   Size               Voltage        C@48v   Eff.    Weight   Public Protocols
  48/1000 HE   1000W    72.0×41.5×217.0   43.5 - 57.6V   20.9A   95.5%    850g    CAN, I²C
  48/1800 HE   1800W    72.0×41.5×217.0   43.5 - 57.6V   37.5A   96.0%    850g    CAN, I²C
Emerson/Vertiv
  • CAN: https://endless-sphere.com/forums/viewtopic.php?f=14&t=114785
Code:
  R48-1000e3   1000W    52.0×41.0×152.0   42.0 - 58.0V   20.8A   95.4%    600g    Nothing yet
  R48-2000e3   2000W    84.5×41.0×252.5   42.0 - 58.0V   42.0A   96.2%   1130g    Nothing yet
  R48-3000e3   3000W    84.5×41.0×330.0   42.0 - 58.0V   62.5A   96.0%   2000g    Nothing yet
ImPow
  • CAN: https://endless-sphere.com/forums/viewtopic.php?f=14&t=114786&p=1697370
Code:
  R481200H1   1200W    70.3×42.5×253.0   42.0 - 58.0   25.1    96.0%   1000g    CAN
  R482000H1   2000W    70.3×42.5×286.0   42.0 - 58.0   41.6    95.0%   1300g    CAN
  R483000H1   2000W   106.0×42.5×286.0   42.0 - 58.0   62.5    96.0%   1900g    CAN
Huawei
  • Voltage mod: https://www.znds.com/tv-1170402-1-1.html
  • CAN/Voltage mod: https://endless-sphere.com/forums/viewtopic.php?f=14&t=86038
  • CAN: https://github.com/craigpeacock/Huawei_R4850G2_CAN
  • CAN: http://bbs.38hot.net/thread-101073-1-1.html
Code:
  R4850G2   3000W   105×40.8×281.0   42.0 - 58.0   62.5A   96.0%   2000g    CAN
Delta
  • Voltage mod: https://www.bilibili.com/video/BV1RM4y1A7p1
  • Voltage mod: https://www.bilibili.com/video/BV1t7411j7u1
Code:
  ESR-48/56    2880W   125.0×41.0×269.9   40.0 - 59.0V   55.0A   91.0%    2000g    Nothing yet
--> You can find a lot more results on mods using "model + 改可调" which means "voltage mod".
  • ImPow R483000H - Datasheet.pdf
  • Eltek Flatpack S 48v.pdf
  • Huawei R4850G2 - Datasheet.pdf
  • Huawei R4850G2 - User Manual.pdf
  • Delta ESR-4_56A C - Datasheet.pdf
  • ImPow R481200H - Datasheet.pdf
  • ImPow R482000H - Datasheet.pdf
  • Vertiv R48-2000e3 - User Manual.pdf
  • Vertiv R48-1000e3 - Datasheet.pdf
  • Vertiv R48-2000e3 - Datasheet.pdf
  • Vertiv R48-3000e3 - Datasheet.pdf
  • Vertiv R48-3000e3 - User Manual.pdf
WOW excellent resources, thanks so much for contributing this!
48V is a sweet spot for "backbone" distribution, minimizes distribution losses using cables with lower currents bussed throughout the system using smaller, less expensive conductors
then using quality DC-DC chargers & converter modules close to their loads as secondary voltage sources.
A link to a useful post on the forum:
Delta
Code:
Hello, this video was posted by me. There are two options, one is 0-60V, 0-50A; the other is 0-120V, 0-25A. Last month I announced the Zhongheng APR48-3G solution 42-60V, 0-38A
