Kinni420 said:
Hows that Phat ride coming along? Must be working good since we havent seen a new post in a while? Or is something not good?
I've got a few goodies to tell - mostly boring stuff. I have some ambitious things I'm working on, but I need to get closer-to-done on those, then I'll lay out some good info. But I can tell you these things....
1) The Hyperion charger backed by Neptronix dual-HP power supplies KICKS ASS. Even though the fans in those power supplies sound like a jet plane taking off, you can't argue with the available power. The Hyperion is really...weird...compared to the iCharger, but it's definitely a precision instrument, giving me voltage to three decimal points where the iCharger does it with one place of precision.
2) I've been using the LTX chargers from cell_man. It's still a little early to tell, but early results are good, very good. They don't get as hot as the ones from BMSbattery. They are smaller and their massive 4 amps of current capability do a fine job. I still haven't cracked it open to tweak the voltage up so I'm only putting 870 Wh (measured with a Kill-A-Watt meter at the AC jack) into a 1200Wh LiPo pack. The plan is to dial it up a volt or two and try to get that 1200 watt-hours I paid for.
So you should be able to tell by now that I'm not gonna get caught without a charger again in the future.
THANK YOU cell_man at http://www.emissions-free.com/store/ for great chargers!!
3) hero_004 has been working to get his Razzo on line. His bike is coming together well and will be a cruise missile when he's done - I'm expecting the Razzo to leave the Phat Bike in the DUST!
We've been busy solving the typical problems with an ebike build. First we whipped up a quick LiPo battery harness with 10ga wire. Anderson 30A on one end and 4mm bullet, split, on the other end. His spare power supply was an ultra-wimpy wall wart brick to drive his iCharger. It could supply only a whopping 200mA instead of the rated 800mA the label had on it. (Yes, I said .2A. It took 24 hours to charge 1 Turnigy 5Ah brick)
That just would not do. So we modded an mATX power supply to drive his iCharger. Works like a CHAMP and was easy as pie to do - took about 35 minutes start-to-finish. Hardest part was cutting away all the wires. We used only the CPU power plug wires - they carry +12v at over 10 Amps on this power supply. After we were done, this free little monster with 10A capacity at 12V was providing the 6A the iCharger needed without breaking a sweat. The variable speed fan was barely turning, and the brick was charged in less than 45 minutes. hero_004 was smiling the EV grin even off the bike. That's one charging challenge kicked and sent running!
I'm kicking myself for not doing this sooner. It was easy and I have a few old PC power supplies laying around that are perfect for driving an R/C charger. If you are using a 6S R/C charger for balance-charging LiPo and you have a spare PC power supply knocking around, even an OLD one, you've GOT to convert it to drive the charger.
Here's an excellent HOWTO on instructables.com:
http://www.instructables.com/id/A-Makers-Guide-to-ATX-Power-Supplies/
4) Made it over to Durham, NC on June 15 for the New Belgium Fat Tire "Tour de Fat" Bicycle Festival. If you ever get the chance, YOU MUST GO. Not only is it a great party, all proceeds go toward bicycle advocacy in the local area where the festival is held. See here for dates when a Tour de Fat will be in your area: (http://www.newbelgium.com/events/tour-de-fat.aspx )
The TdeF is fantastic: many $5 pints of great beer, writhing liberal bodies dancing to pulsing music and more bikes than God. ebikers are still "spies in a foreign land" - I saw only one bike-like vehicle with electric assist - but still, these are our kindred folks and I wanted to spend a Saturday afternoon partying with 'em.
While there, I got to see and ride a "Bullitt" Bakfiets-style cargo bike. I fell in love with it, but riding one is an acquired taste - they turn like a canoe, not like a bicycle at all. But the
vast cargo area up front would be perfect for an across-america bike tour and about 40Wh of LiPo laid down flat in the floor of the cargo area! What a dee-licious rangemaster that would make!
5) Oh, and by the way: the Phat Bike carried me 20 miles at WOT through 20 miles of "the worst downpour ever" and survived to tell about it. After letting the bike dry out, the only damage is the rust inside the chainring nuts. The motor, CA, controller and batteries (in the FalconEV bag) got through it just fine. I probably should write up what it was like to ride 20 miles in "the worst downpour ever" but I don't have any photos, so as Hyena says: "pics or it didn't happen!"
Gasoline has gone back up in price here in central NC, southeast USA. After bottoming out at about $3.23 way back in late May/early June, gas is now back up to $3.59/gallon and I'm (as usual) massively pissed off. I'm so freaking TIRED of being an ATM for the gas companies.
I know our European brothers and sisters chuckle when I complain about such a relatively cheap price for petrol, and I don't blame them. What's killing me are the price fluctuations. It's possible to buy at "the wrong time" and end up paying a few bucks more than if you had waited 24 hours. I've seen the price swing as much as two bucks over the cost of a tankful within an hour. That kind of uncertainty of price drives me nuts.
I've had the Phat Bike out on a few grocery, food and errand runs (and a 20 mile test run) and it feels
mighty good to ride by the gas station realizing I'd never need to stop as long as I'm on that ebike....
What next?
Many Lumens about to return to the Phat Bike. Will motorists look away in fear?!?!
Balance charging the Phat Bike sucks. Can it be improved?
Moving the controller from the rear rack to the seat tube. Is it just a change of position...or much more?!?!
Return of the Crystalyte HS: the Sapim spokes look awesome and the HS3540 is back better than ever.
Testing a new tire, the new version of the Bontrager "Hemisphere". Can it compete with the Schwalbe Marathon?!?! Stay tuned!
There's still a windshield question left unanswered. Will it finally be put to rest?!?!
