Not yet but I'm expecting it. I bought the 20 ah size to hopefuly avoid issues with the battery being able to deliver less power when at desert temps. I haven't had a 100 degree ride home yet, but have had some in the high ninteys. I did notice the battery was good and hot by the time I got home, an hour of hard ride. Since I heard you should not charge a real hot battery, I used a square aluminum cookie sheet to make a container for the battery. The aluminum was cut at the corners and folded, in such a way as to avoid sharp edges, into a sort of a bread pan shape around the battery. The battery now is cooler when I get home, and cools off much faster after a ride. The aluminum makes a kind of heat sink to transfer the heat away faster. I also ventilated the battery bag I carry it in better. An I put the BMS where it does not touch the battery directly. At hardware stores you can buy aluminum tape, for use on hot ducts. I just had the cookie sheet handier, and wanted some bash protection. Another Idea I did not do since it was harder to fit on the carrier, was to put the battey in an Ice chest, with a cold pack or two under it, and some type of way to keep the battery above all that, dry. That's two now I know of with 1000 miles on a duct tape pack. Hooray! I'm hoping for 5000 miles a year, for at least two or three years. Good luck and tell us how your solution works out.
