Doctorbass
I had this idea since few month and i decided to try that when i found the thread about the RSP-2000 power supply.
Yesterday i built my 1500-2500W charger for 30s lipo ( 126Vdc) from 2 meanwell RSP-1000-48 connected in serie and i also used 4x DC-dc converter BXB150 connected in 2s2p to boost the voltage of each meanwell to 63V.
I have installed a switch on the second shunt resistor to allow full power from a 120V 15A outlet or from a 220V 15-30A outlet. It work great!
The overall size is the same as the RSP 1500 model but is having a heatsink and 4 DC-Dc converter on it to boost the voltage.
The measured efficiency between the AC input POWER and the DC output POWER is 84% while the Power factor remain 0.99.
The efficiency of the DC-DC is in the best optimum area of the input voltage vs efficiency curve since i am supplying them at 50Vdc from the adjusted meanwell so the lost of the dc-dc is minimal.
I also added some protecting diode ( shottky) on the output of the DC-DC to protect against reverse current flow during the momentanous unsynchronized power up of all the serie source.
I now have my portable STABILIZED cc-cv 30s cahrger that i can use for 1500W or 2500W output depending if i can connect on 120 or 220V outlet by a simple flip of a switch :wink:
Doc
Doc
