createthis
- Joined
- Jul 14, 2015
- Messages
- 22
I've been doing some research. No research is perfect, so feel free to correct me if/when I miss something. I've noticed that "portable solar generators" (think: goal Zero Yeti line) tend to be 12v. Also, e-bikes and skateboards tend to be 48v.
I was thinking... what if I combined the two somehow? A vehicle that was also a fully functional portable solar generator, in other words. I mean, that vehicle, when it's sitting still, is a giant battery. Seems like it would be handy to be able to use it to power things like laptops and cell phones.
First, I tried designing a 48v solar generator. I ran into trouble at the 120v inverter. Most small inverters ( less than or equal to 1200 watts ) take 12v input. I think the big expensive heavy Outback residential solar lineup has an inverter capable of running off a 48v supply, but I couldn't find anything smaller. So, basically, you can build a 48v solar generator with an ebike motor, but you can't plug your laptop into it unless you lug around an expensive and heavy Outback inverter, or you build your own from scratch. Boo.
Ah-ha, I thought. Fine. I'll make it all 12v. So, the solar generator becomes relatively easy. LifePO4 batteries to save weight. Some kind of BMS so they don't burn. A couple of light weight Genasun charge controllers. Any off the shelf 12v inverter, like a Xantrex ProWatt or something. No problem. But now, I get stuck when I want to drive the motor. Most e-bike motors want 48v so they don't overheat from all those amps. I looked around for a 12v to 48v dc-dc boost converter, but I couldn't really find anything over 200 watts off the shelf. Also, there are losses with a boost converter. 80% efficiency or so, right? So yeah, I know I could engineer one, but probably expensive, heavy, and lossy. Boo.
So, I was thinking... if I have 4x 12v batteries, I can arrange them in series for 48v and parallel for 12v, right? Is it possible to design a relatively simple circuit that allows me to do both at the same time? For example, I'd like to be able to charge at 12v and run a 12v inverter and drive a 48v motor. I'm not an electrical engineer. I have some basic electronics theory under my belt, but I don't think I've ever seen a circuit that can do this. It kind of hurts my brain thinking about it. Is it possible?
Thanks,
Jesse
CreateThis.com
Thanks,
Jesse
CreateThis.com
