markz
100 TW
What value and style of fuse am I suppose to use on the positive power line?
I have the Lyen 18fet rated for 65A, but likely push it higher.
http://www.be-electronics.com/category_s/1963.htm?searching=Y&sort=1&cat=1963&show=300&page=1
I bought 150 ohm 5 watt made by NTE from same store B & E Electronics, will put it on the + line.
Where do I hook up the switch on the power + line? in series? And this will be the main power kill switch? And I should locate it on the handle bar for quick turn-offs?
Then I should also have an iginition switch, also located on handlebar, ideally close to throttle?
