RageNR
- Joined
- May 23, 2016
- Messages
- 216
Hello everyone. Long time (on/off) lurker. Been meaning to make an account for.. 7 years?? LMAO
Anyways, I am getting ready to build an ebike. My first in fact. I have a lot of ideas and even more questions.
(if anyone has the newer Cyclone setup or kit from Luna Cycles, I would appreciate your input on measurements. Read 2nd part please)
1st off - The Platform
I just picked up a 1996 ProFlex Beast today for a few bucks. I have researched this bike for about a week before deciding to go for it.
Chose this bike for the cost, cool vintage factor, funky design, and good build quality. Basically the ratio of performance/cost.
A respected and OLD full suspension MTB. 26in wheels, with a crazy unique front fork design. I literally just picked it up hours ago, and it needs some work. Right now it is ugly as sin. A few rattle cans will fix that... (I know I am going to catch flak from the vintage bicycle purists. That's ok.. BRING IT ON)
It is a 16in frame, so a bit on the small side. That is ok. I am fine with the the bike being a bit smaller in hopes of a more compact, balanced, lighter weight ebike.
I might mod the frame eventually to accept gas shocks like a RockShox or Fox. For now the spring oil dampend shocks are alright.
After looking at the bike, does anyone have opinions on the frame of choice? I do not have the funds to run out and but a nicer FS frame. For the $$ spent, I think this was about the best "bang for the buck" I am going to get.
2nd - Kit Options
I am planning on buying the Cyclone kit from Luna Cycles. However, I plan on mounting mine in a different fashion.
What I would like to do is mount the motor above the crank if the frame will allow. If someone could get some better measurements of the the Cyclone motor (diameter, depth, circumference), and also the mounting bracket. (overall length, height, distance from center of crank hole to the closest point of the motor when mounted).
I understand that this may change how the bike handles due to the weight being up higher. It may not work out so well. All I can do is try and see how it goes.
The idea is to eventually make an enclosure around the midframe to make the appearance more stealthy. Of course, adequate airflow will have to me maintained.
3rd - Output Goals
I would like to push this motor to hopefully upwards of 1800 watts. Closer to 2500 if my electronics will allow.
I'll just list what I am hoping to achieve:
- 72v Nominal (84v fully charged?)
- Dual Voltage setup 36v/72v (i will expand on this later)
- If dual voltage does not work out then 60v triangle pack
- 50+mph. Hoping to achieve 55-60mph
- Range? Have no idea. Reason for dual voltage setup. 30+miles on 72v would be nice
- Retain at least some of the MTB suspension travel
- Stealthy as possible
- Mild mode + H4UL A$$ mode
- Maybe a nice 4k 17in and bluetooth hometheather soundbar
4th - Electronics
So I am hoping to be able to use a dual voltage setup. 72v/36v.
Reason is, I want to haul a$$ as well as be able to ride in the city with some good range. My idea is to buy 2 identical 36v packs and make a small jumper to allow me to plug in the batts in series or parallel.
Doesn't sound too complicated. I just wonder if the controller will handle a lower voltage well if it was designed to run a higher voltage. Amps will be 2x on 36v = 60amps total.
So that leaves 2 questions..
Will the stock controller that comes in the Luna Cyclone Kit handle 84v ok? I know it is rated up to 80v. Surely 4v more will not be a problem. If it is, I could use a charger like the GRIN Satiator to charge to 4.05-4.1v to keep the voltage down, and prolong the life of the battery pack.
Can that same controller effectively use 42v-36v? Or be made to work?
These are the batt packs that I have in mind: http://lunacycle.com/batteries/packs/36v/36v-samsung-or-panasonic-ebike-rear-rack-14-5-or-17ah-w-charger/
My concern is that they can only support 30amps. In 72v mode you have more voltage to offset the amp draw. Will 30 be enough? In 36v mode I will have 2x30amp = 60amp. Seems sufficient at least for 36v. I think I will use these in a backpack. Have the connector just under the bike seat, batt packs go with me when I walk away from the bike.
If the dual voltage does not work out, I may have to settle for the 60v triangle pack.
Luna does not offer a 72v. So either I have to buy from somewhere else, settle for 60v, or build my own. And if I go with the 60v triangle pack, I want to try to fit it in the frame.
Never built a li-ion pack before, though I am sure I could. Not keen on building such a high voltage/capacity pack for my 1st endeavor.
The 60v pack would really hurt my top end. I think it would be difficult to reach 50mph on just 60v. Correct me if I am wrong here.
I most likely will be purchasing a GRIN Cycle Analyst soon. I would also like to purchase a GRIN Satiator charger, if I end up going with the 60v pack. The 36v packs come with chargers to my understanding.
So its super late and that is all I can think of for now. More will come to me later I hope.
Sorry for such a long read. I like to be as descriptive as possible so people do not ask repeat questions for lack of details. I gave all that I could think of.
I want to hear opinions, thoughts, and questions. Tell me of your experiences and ventures.
2nd - Kit Options
3rd - Output Goals
4th - Electronics
