Aushiker
- Joined
- Mar 8, 2014
- Messages
- 170
fingret said:Yep, thanks alot Aushiker.
The thanks is due to pexio not me
Andrew
I'm in.tomjasz said:How many USA Buyer would be interested in a group buy? Ordering 10 cables gets free shipping. I'd coordinate it but would need 7 people to commit to $30 each by Paypal. USA and Canada only. Any overages would be refunded the buyers. If there is enough interest we could get the price down to nearer $26 delivered.
I'd happily provide full disclosure, address, phone number, etc, to anyone interested. I am well known on another forum with 15,000 posts and dozens of sales of pieces and parts for Vespa scooters. No scam, just a way to get this done for myself and others at a more reasonable rate.
teslanv said:Yes, you can De-rate the Current in the programming on the older BBS02 models. - Newly released model??? Hard to say. Bafang might have changed the Firmware.
mclark999 said:Maybe we start a loaner service. My 280Z forum started loaning out a custom made spindle tool. Would people be interred in paying like $10 plus postage to borrow/rent a cable and usb card?
Yes, I believe you can set the LVC to as low as 36V. I had mine programmed to 38V when I purchased it new (12S LiPo) but as soon as user programming became possible, I bumped it up to 42V, because I want my batteries to have a long meaningful life. And even then, I rarely discharge below 45V.savaoaknyc said:hi ,
just a question about the minimum cut off voltage of bbs02 or bbs01.Can i set the minimum cut off at 2.8v per cell, so in case of bbs02 it will be 36.4v and with bbs01 28v??
Any information about this???
svennis said:Hi
I am new in this forum. Yesterday I connected to my BBS01 and made some changes to some parameters. I followed the instructions in this thread when creating the programing cable.
I connected against the controller and pushed the read button, to fetch the information from my controller. After changing the Keep Current[%] and some other parameters, I push the write button. This was a success.
I connected the display and turned on the power. Everything looks normal. However, when I start to pedal the display only shows ERROR 11. Moreover, I am not able to connect against the controller with the cable I used to do the programming.
Do any of you have any experience with the ERROR 11?
teslanv said:Yes, I believe you can set the LVC to as low as 36V. I had mine programmed to 38V when I purchased it new (12S LiPo) but as soon as user programming became possible, I bumped it up to 42V, because I want my batteries to have a long meaningful life. And even then, I rarely discharge below 45V.savaoaknyc said:hi ,
savaoaknyc said:thx, very much.In this case i will buy the new panasonic bd cells, i had some doubt about the programming to 36v cut off .At 40 low cut off or 3.0,3.1 cell level, they give around 2.8ah,which was not perfect for me.Just wanted to squeeze out the full 3ah of the cell,
Greets Sava.
No idea why the cable doesn't work but amigafan had issues with error 11 which he solved.svennis said:Hi
amigafan2003 said:Sorted it - I was trying to program the amp limit from 18 to 20 at the same time - it was this causing the err 11 - so it seems the controllers have a max amp limit hardcoded somehow (still happy at how it perfoms at 18a though!).
teslanv said:savaoaknyc said:thx, very much.In this case i will buy the new panasonic bd cells, i had some doubt about the programming to 36v cut off .At 40 low cut off or 3.0,3.1 cell level, they give around 2.8ah,which was not perfect for me.Just wanted to squeeze out the full 3ah of the cell,
Greets Sava.
Figure 15 whs per mile if riding a moderate PAS setting and 30 whs per mile if using throttle only, and size your battery accordingly. If your battery is too small, and cannot provide the required 25A continuous draw, it will not be a happy battery, and you will be buying another battery sooner than necessary.
CdnE90 said:tomjasz said:How many USA Buyer would be interested in a group buy? Ordering 10 cables gets free shipping. I'd coordinate it but would need 8 people to commit to $30 each by Paypal. USA and Canada only. Any overages would be refunded the buyers. If there is enough interest we could get the price down to nearer $26 delivered.
I'm in.
