tomjasz
1 GW
WHOAH dude. There's more sideways posts than I can count. I'm happy to read and help on TTL issues. Green to white is a common solution and this is just the place to talk about it. Can't program if you can't get a cable right.
I'm looking forward to the lessons you share. Best wishes for a successful tweak.dusan said:Yes, you are right tomjasz, I will probably broke warranty but I would like to use Bafang PAS maybe as torque simulated. It would follow my higher cadence with motor higher rpm. Because currently, algorithm just take care about some low cadence limit and then it starts to assist with some power peaks.
Or simply said, I would like to have current control settings.
What do you mean with "the usb cable"? A ready made cable from one of the forum members or webshops?Bazaki said:Guys, I have the usb cable and connect it to bbs01 motor, i start up software and I see com 7 and 1200 bd but i can not read or flash data.
any idea ?
vvvv said:are the bbs01 250w and 500w the same model but programmed with different max amps ? i.e. if I get 250w and reprogram it to allow up to 500w will I have the same perforamnce as with 500w motor?
opperpanter said:No. They are completely different, mainly different winding for different speeds/voltage.vvvv said:are the bbs01 250w and 500w the same model but programmed with different max amps ? i.e. if I get 250w and reprogram it to allow up to 500w will I have the same perforamnce as with 500w motor?
Yeah, I misread. I thought he was comparing bbs01 250 with bbs02 500.vvvv said:opperpanter said:No. They are completely different, mainly different winding for different speeds/voltage.vvvv said:are the bbs01 250w and 500w the same model but programmed with different max amps ? i.e. if I get 250w and reprogram it to allow up to 500w will I have the same perforamnce as with 500w motor?
Those are both bbs01 36v versions, the only difference i see in two products in the power.
I agree, but there is 250w limitation in some countries so maybe it is the same model with just soft limit of 250w.DaDo.Bzz said:Funny thinking. When you buy 2 GHz procesor, you can try to overclok it to 4G what would happen. )
There are no Fet transistors capable to handle 500W eventhough motor is the same. You would need also upgrade firmware.
There are two freewheels inside the BBS01 and 02 motors. One is on the main crankshaft and allows the crankshaft to turn even when the pedals are stationary. This one clicks. The other freewheel (which is silent) is on the intermediate shaft and allows the pedals, crankshaft and intermediate spur gear to turn without spinning the motor (pedalling without power to the motor). Have you managed to lock both out?vvvv said:is there any way to make this motor rotate in reverse ? I offer $20 thank you gift for anyone who can give clear instructions to reverse the bbs01 spinning direction 8)
The external parts to the motor in my construction allow reverse rotation of motor shaft i.e. no external freewheel.
mfj197 said:There are two freewheels inside the BBS01 and 02 motors. One is on the main crankshaft and allows the crankshaft to turn even when the pedals are stationary. This one clicks. The other freewheel (which is silent) is on the intermediate shaft and allows the pedals, crankshaft and intermediate spur gear to turn without spinning the motor (pedalling without power to the motor). Have you managed to lock both out?vvvv said:is there any way to make this motor rotate in reverse ? I offer $20 thank you gift for anyone who can give clear instructions to reverse the bbs01 spinning direction 8)
Michael
Parameter "Limit current" actually doesn't have anything with current, it simply set throttle voltage.
